spinelli 25 pitch vs. 24 hydro's
I am trying to decide which prop to go with on my 95, 32' caliber/outlaw. Does anybody have any suggestions on which one I should go with?
if your drives are deep in the water go with a mirage plus 3 blade, if your boat will not get on plane with a 3 blade prop cause your drive's are mounted on the high side then a 4 blade will do the job, most deep V hull boats like a bravo1 prop[non step hull] Hydromotive props [Q4 ] lift the stern, but they have a new bow lifting prop out now, you can also try turning your props in and then try turning then out to see what your boat likes.
I would recommend trying both props on your boat. Both props have some positive benefits to them. It really boils down to what feels better to you!
Julie
Julie
good suggestion Julie...would you mind buying the two different props for me so I can just try them out? lol, hey I have a better idea, why don't I just buy every make,model, pitch on the market and try them out to see which one works best ! I sure wish I had your money Julie !!!! lol, lol
I think I'm just going to go with Hydromotives, I had them before and I thought they worked well. Julie, do you have a pair of used 24 pitch for sale...cheap?
I would go with the hydro's that works best on the 32 caliber 94 to 95 year but most
come from the factory spinning them out i spun them in and had great results.
but like julie said if you can try them both and if they need alittle work send them
to THROTTLE-UP!!!!!!!!!!
ok baja 36...you have 25 pitch for sale and another member has 24 pitch for sale. So now my problem is not knowing if I should go with 24's or 25's ! What was your rpms/speeds?
