AFR Exhaust Ports (Pipe Dreams?) >
Old 01-18-2005, 09:55 AM
  #81
44MTI's Avatar
Default Re: AFR Exhaust Ports (Pipe Dreams?)
Did you really say 7500.That is amazing.What type of rotating assembly are you running?
and what are you running this in.It has to be fast with rpm's
44MTI is offline
Old 01-18-2005, 10:10 AM
  #82
GPM
7500, Crower crank, crower billet rods, wiseco pistons. I usually wait till the end of the season just in case something breaks. The engine has been fine , the outdrive is another subject. I just do it for fun see if it will stay together.
GPM is offline
Old 01-18-2005, 10:17 AM
  #83
44MTI's Avatar
No way I could turn that many rpm's.So far only about 6200 on the limiters with about 10% slip 33's and 1:35's. I may try turn some new prop's 6500 but probably won't be able to get there. What boat are you running this in?
44MTI is offline
Old 01-18-2005, 10:23 AM
  #84
GPM
26 cat, I think the procharger has something to do with it.
GPM is offline
Old 01-18-2005, 10:34 AM
  #85
JimV's Avatar
Originally Posted by 42MTI
That's what I'm thinking also, I'm just wondering what Jim V meant in his post yesterday that got deleted with all the others.
42MTI
I was not Bashing the Brodix heads. I haven't flowed them or seen them other than PRI show. I'm sure their a good head. I guess the point I was trying to make is to make sure the airflow numbers match to the manufactors advertised numbers, which I found out the AFR's do not. Which post's got banged?
JimV is offline
Old 01-18-2005, 10:46 AM
  #86
JimV's Avatar
Originally Posted by Mr Gadgets
Jim,
any more research on the flow with an exhaust header? Did you get any info on the 18* Darts?
I have a sheet on a 383cc CNC Oval port. PN 16800000; 102cc chambers. The numbers are good at the high lift, but it was tested on a 4.500" bore. Put it on a real motor with 4.605" bore and a 4.875" stroke and it might just work?? What do you think Jim?
Dick
Dick here are the numbers Dart gave me at PRI
Intake.................Exhaust
.2.......162............136
.3.......236............177
.4.......314............216
.5.......376............254
.6.......420............289
.7.......444............316
.8.......450............330
The left intake port flowes less @ .700 and .800 lift
JimV is offline
Old 01-18-2005, 10:57 AM
  #87
44MTI's Avatar
I didn't think you were bashing, your way to sharp for that. Its just that I know very little about this, Just enough to be dangerous. It is turning into a pretty big project for me financially speaking and I would like to make as much of it as possible. I think I'm probably over thinking it. I have to order some heads this week, Which one would you goe with.
Again the combination wil be either 598's or 572's, quad rotor's intercooled and conventional headed running carbs on either 93 or 100ll just for insurance
Dart pro1's, brodix 2x or 3x all cnc versions. Thanks for all the help, I would also be interested in prices if you have time, I want to reuse as much of my old hardware as possible.
44MTI is offline
Old 01-18-2005, 11:42 AM
  #88
P Offshore's Avatar
Jim,
I need advice too...
I sent an Email.
P Offshore is offline
Old 01-18-2005, 11:47 AM
  #89
44MTI's Avatar
There goes the thead.
You need some good 2x's just broken in.
44MTI is offline
Old 01-18-2005, 11:56 AM
  #90
P Offshore's Avatar
BROKE in !!!
Quick Reply: AFR Exhaust Ports (Pipe Dreams?)
