bravo one drive resivoirs
Its been 3 summers and I could not stand it any more ![Big Grin](/forums/images/smilies/biggrin.gif)
Don't tell the girl friend, shes getting Whipple's for Christmas
http://www.offshoreonly.com/forums/s...ad.php?t=90540
![EEK!](/forums/images/smilies/eek.gif)
Originally Posted by Strip Poker 388
The old round style I have had problem cracking and leaking . I am trying to find a better ,larger reservoir.
you need to scroll down, bottom of page has the square bottles with and without plumbing.
Not to slam Teague but don't bother, have had wrong parts sent more than once and stuck with shipping cost. I forget the guys name on the fone but have heard from others here that he isn't too sharp.
Chris G.
Chris G.
Originally Posted by Biggus
Are you sure you have '99 transom assemblies? Because they did not use a gear lube reservoir on the 1988 (first year) Bravo drives.
My guess is that you have the '88 transom assemblies. If you had the newer ones and there was no lube res. connected you would have gear lube in the bilge.
...unless the lube hose inside the boat was plugged.
I have '88 transom assemblies and 2000 Bravos/ no reserviors. Is it possible to have them or am I outta luck?
Yup, all you need its the kit that Strip posted the link to.
Your drives will be much happier with the increased gear lube capacity.
Kurt
Kurt
Kurt
Kurt
![Drink](/forums/images/smilies/drink.gif)
Well I got the hose for the resevior inside the bilge. I think. But the problem is in the transom assembly. There isn't a hose that connects to the gimble ring that would connect everything together. Is there something I can buy? or am I SOL?
Are we having fun, yet?
Diversified Marine Sales in Jensen Beach, Fl. has the OEM reservoir kits for $129.99. I saw them on E-Bay.
www.diversified-marine.com
Jay
Jay
1BIGJIM
Drives and Lower Units
3
06-10-2008 12:46 PM
panteraracin
3
02-07-2002 10:36 PM
