smallblock power >
smallblock power
smallblock power
Old 12-15-2004, 09:50 PM
  #41
Neno the mind boggler
glassdave's Avatar
Default Re: smallblock power
Originally Posted by fund razor
Hey Dave,
What's the difference between the two intakes?
I put a regular performer on my Nova. My friend put the RPMs on his Donzi.
If I don't have a major fiberglass crisis I was gonna go through the blocks and maybe do intakes. I need exhaust manifold gaskets on both blocks. I thought I would do exhaust manifolds too. Not gonna cam them or anything though.
Maybe upgrade ignition systems. Maybe.
No wonder you can go faster than me. I'm running stock 260s.
the air gaps have a cooler denser air charge. the manifold has an air gap under the plenum to help it keep cool and we all know thats better for preformance. my mirage had that an the 270H cam an it ran like a scalded dog. i have the 260's in the scorp but am seriously thinking of switching this spring to the 270's. if you are gonna have the tops off your motors how bout droping in a pair of 260 cams,if i upgrade i think i know where you can get some cheap
08 OPA High Points Champion
glassdave is offline
Old 12-15-2004, 09:54 PM
  #42
glassdave's Avatar
Originally Posted by cuda
My 87 320 EFI had a flat tappet cam.
The reason I didn't go to standard Vortec was because it's damn near impossible to find a cast iron manifold for them, and I run in salt. Also the issue with the max lift, though the one I chose would have been at the upper limit of it without machining.
here ya go Cuda genuine GM cast iron vortech intake its a Q jet manifold though. but its a start
Old 12-15-2004, 10:34 PM
  #43
ratman's Avatar
Wife gave me $5,000 to buy a boat
does the wife have a sister? im gonna be needing 2 new stainless marine exhaust systems complete! thx in advance
ratman is offline
Old 12-15-2004, 11:16 PM
  #44
glassdave's Avatar
than yer gonna need two of her sisters
Old 12-16-2004, 08:47 AM
  #45
fund razor's Avatar
Thanks.
Makes sense. That's what I was picturing, just haven't seen one. I have tons of overhead space, so I could do a taller intake. I'm assuming that it's taller. The extent of motor work is gonna be based on the assesment of the hull.
fund razor is offline
Old 12-16-2004, 09:24 AM
  #46
blkhorse's Avatar
so, if I am starting with 270 hp,add the g.m. vortech heads,270 cam,air gap manifold,stock carb.what would you estimate the horsepower at? is this putting the alpha at serious risk? also what ign.system that seems to hold up?msd?
blkhorse is offline
Old 12-16-2004, 03:24 PM
  #47
glassdave's Avatar
i would stick with the stock T-bolt. its a great ingition. i would guess HP would be in the 350-375 range give or take a few. the heads are whats gonna pull that package together. your Alpha should be fine just use your head when throttling it. i beat the snot out of mine in a 6000+ pound boat and they do fine as long as im not hit'n chit
Old 12-16-2004, 03:56 PM
  #48
blkhorse's Avatar
well then,it looks like I have a plan.
Thanks all!
blkhorse is offline
Njawb
06-28-2008 02:43 PM
TeamSaris
10-29-2006 11:34 AM
FX10
Superboat
24
02-03-2006 06:43 PM
resurrected
25
03-30-2005 07:49 PM
FX10
Superboat
19
09-14-2004 09:42 AM
Quick Reply: smallblock power
