High Volume sea pump options
Re: High Volume sea pump options
The kit was $250 and the only modifications required were driling holes in the mounting bracket. Pretty easy to retro-fit. I bought the pump because they claimed the impellar was nearly indestructable and they were willing to warranty it for 1yr with no questions asked if the inpellar fails. They claim you can run the motor dry and not hurt the impellar. I didn't notice increased flow, but never really checked. Their claim is the pump moves more water, but I cannot verify. I lost an impellar last season and went with this pump because of its durability claims.
How about teeing off the cooling system before the heat exchangers and feeding the oil coolers? Almost like what you would do for a chiller. This may increase water flow to the coolers and bring down temps. My problem is the opposite-my oil temps are too low and I'm installing thermostats to bring them up
I think I will check them out Wette Vette. Do you have a web site? I run KE headers and am looking for more insurance against melt down. Because I run closed cooling, it may not be quickly evident if I lost sea water flow. May install pressure gages too.
Ted, the oil coolers are first in line after the seapump. They get the coldest water. But if the water flow through the cooler is too low due to other restriction upstream, the water will become thermally saturated and my oil will heat up. I'm wanting more flow through the coolers for this reason. The more I yak the more I think the engine heat exchanger may be the constraint.
Could be the suction side as well though. Anyone ever install thru hull water pickups before? What are transom pickups?
BT
BT
Offshoreonly Advertiser
After chasing hi oil temp for years, I finally figured out that the problem was really the oil pan. Once I got that handled was able to run 3 x 12 @1000 HP, also close cooled. BTW what do you consider hi?
I had pressure gauges at the feed for the headers. Just as you suspect you can have an exhaust melt down before the engine overheats.
Marc
www.mercruiserparts.com
www.go-fast.com
www.bammarine.com
www.cyborgtransmissions.com
It's not alive -www.BoatStuffExpress.com - temporarily retired
Marc
www.go-fast.com
www.bammarine.com
Blue Thunder,
I went with external pickups and strainers after the stock Bravo style water inlet corroded to about a 1/4 " opening. I have some new Stainless Marine transom mount pickups I'll let ya have cheap. Not sure where you are on the Bay, I may not be that far from ya. I'll be glad to show how my pickups are setup as well. PM me if your interested.
Yeah, I figured the heat exchanger might be reducing flow volume and that's why a T in front of it might give you more flow through the cooler and then just dump them out the side. Transom pickups mount at the deepest part of the V on the transom-best place to pick up water for full flow and nowhere near as much restriction as a drive pickup. I am running crossovers with no thermostats so the temps stay low, just need to bring the oil temps up a little and it will be all good.
the drive pickup is a big restriction on the suction side u must go to hull pickups as they will feed the system at speed and just blow thru the merc pump then u trim the pickup to adjust the water pressure as it is easy to have way too much pressure if you insist the large diesels run up to a 4 inch inlet and discharge picture your exaust hose on the inlet to seastrainer! we run a globe impeller in a merc pump(soft so it is easy to bypass)we had to glue and safty wire all the hoses on as the first test we had 140 psi inlet pressure ! all hoses are 1.250 and we bleed off water for the intercooler at the sea strainer that we installed a pressure relieve valve to dump excess overboard(1400)hp
Site pages are slow to load , I gave up on a few.I have never heard of these guys??
http://www.team-kpm-racing.com/products/index.html
http://www.team-kpm-racing.com/produ...ges/page3.html
