High Volume sea pump options
#31
Are you still sucking through the stock drive pickup Cal? I think different high capacity pans are in my future. Anyone have two good used pans to sell? I am going to work my heat exchanger restriction idea some. I think that is a contributor too to a restriction in flow. Maybe do something like Insptech was suggesting... a dump of some sort. Last but not least, I think a set of water pressure transducers and gages are in order. That is my primary objective anyway.... not frying my headers.
BT
BT
![Cool](/forums/images/smilies/cool.gif)
#32
Toxic FORMULA
Originally Posted by blue thunder
Are you still sucking through the stock drive pickup Cal? Last but not least, I think a set of water pressure transducers and gages are in order. That is my primary objective anyway.... not frying my headers.
BT![Cool](/forums/images/smilies/cool.gif)
BT
![Frown](/forums/images/smilies/frown.gif)
Transducers for w/p??? Every w/p guage I ever had was strictly mechanical , like a mini speedometer in psi not mph.
#33
Originally Posted by mopower
Yep , thru the Bravos. Ones a 95 with side pickups and the other is an 02 with dual pickups and that's more trouble than it's worth
#34
i just bought a pair of 2 stage K.E. water pumps from tyler crocket for 675.00 each cheapest i could find them anywhere. tyker was great to deal with. ratman
#35
Toxic FORMULA
Originally Posted by offthefront
cal .. so you run water up to dash ?
Yes , I do. Three times...speedo and two w/p guages
FlyFast
4
08-09-2004 11:52 AM
