ok this may be a stupid question......
how come no one makes a Big straight 6 like 400-500 cu inch, 400hp +.
seems like it would be easier to work on in a boat with a twin setup,
and reduced weight.
and reduced weight.
Re: ok this may be a stupid question......
Hmmm... interesting thought. And it would sound like a bread truck. Seems that the old pickup trucks with straight six's did pull pretty good.
There was an old Mathews that I worked on in the 60's that had a big 6 cylinder (about the size of a vw bug) that had twin plugs in the top for each cylinder. Cant remember the brand name but it was in a very old 40 ft mathews, single screw.
There used to be an engine builder years ago that made HUGE gas 6 cylinder engines for trucks... The name of the engine was " Hall-Scott"... They made small engines also for cars back in the late twenties. But... most people don't know that inline 6 cylinder engines of the same cubic inches as a V-8 weigh more... a lot more.
You have 7 main bearings instead of 5. The block and crankshaft are heavier. Instead of only 4 throws for the 8 cylinders.. Each cylinder has it's own crankshaft throw. The only advantage is width. Not too many people make speed equipment for inline 6 cylinder engines.
Originally Posted by Falcon
What would be interesting is a pair of narrow angle v6's with screw chargers! I'll bet they could get to the 400hp range.
Originally Posted by Reed Jensen
That is what "Torque" motors was trying to do with their 60 degree V-12... make a narrow, powerful, unsupercharged engine. But they had too many "issues"...
Originally Posted by HyperBaja
Any update on how callan did with these last race season?
and reduced weight.
and reduced weight.
As far as a big gas motor, 4 liters is about the high end of the range for a straight six.
Hop up parts? Here you go:
http://www.cliffordperformance.com/
Originally Posted by mcollinstn
You never heard of a Cummins or Caterpillar? I assure you the narrow-ness of an inline six is a benefit.
