Kiekhaefer Zero Effort Throttles
Well, I just got stupid, that would be more, dropped my throttles and broke one!! Is it possible that may know someone or have a throttle lever for sale? Color is not a problem since I am having them re-powder coated but wanted to check the forum and see if possible to replace without buying new. Hope everone has a great "Holiday Season" and thanks in advance for your help!!
Karl
Karl
Try calling a place called Kendor marine. They are just south of Milwaukee Wisconsin and I have seen several new/used ones on the shelf. Sorry I don't have the number here at work.
I have a pair. Black 30 degree angle. $150 delivered. You could keep yours as a spare.
[email protected]
[email protected]
Remove the broken stick and have a good welder patch it up. I broke one last year and the welded stick is stronger than the others.
BT
BT
Thanks guys!!! Reed, Ben Perfedted and Custom, I am trying to stay away from new or replacement but if things don't work out I will get back with you to see what can be done... Blue Thunder, thanks for the welding idea but it took a multiple break and doubt that the look of what it would take to put it back would be satisfactory. I am checking a couple of folks for used and will just have to see. Thanks again guys for all of the input and with my luck I'll bet I'll be calling you soon.
Thanks very much, Karl
a GOOD welder can weld almost anything back together. wilson mainfolds would cut an intake apart modify it weld it back together. then shot blast it to look unmolested and the nascar tech boys did catch it for years... so do be afraid of having something alum or steel repaired. just have to find a highly skilled welder not some bone head that knows how to hold the gun and turn the machine on and off. just my .02 ratman
I just sold my used KK throttles and shifters to Sean here on OSO. He was only using 1/2 of each assembly and should have one of each lever left. If you're interested, try posting on the swap section "wanted".
Due
Due
