Wiring Harness help Where can I get one
Looking for 2 complete harnesses. I need everything including the breaker setup and mounting bracket. Any idea where I can buy these complete? Mercruiser wants to sell me each part seperatly.
I'm switching from efi to carb. They are 502 engines and I will be running thunderbolt 4 ignition. I have the harnesses for the ignition already.
Any help would be great
Rob
Rob
I bought a couple from teague last yr, very reasonable. About $100 bucks each,I bought the ones for 900SC and they were cheaper than some of the other for some reason.
I have one in great condition, It was for a V-6 but will work just fine for a v-8. All the wires are the same. PM me if you want it. I'll let it go for real cheap.
Don't know if you need the "keyswitch harness's" or not, but they are the same whether you have a carb or efi motor. These are the harness's that run from the dash back to the motor...and then plug into the engine harness. The keyswitch harness's are the same for every Mercruiser V-8 inboard or sterndrive, regardless of size. Ed
Anyhow is it complete with the breaker assembly? How much. Let me know you can call me at 440-315-5733
Originally Posted by formula31
Rob
