power for electric fuel pumps ?
The relay will only let electric go to your fuel pump when it gets juice from the coils or ignition switch or oil pressure sending unit, whatever, to close the contacts. A relay is just a switch. You "turn on" that switch by supplying electric to it instead of manually moving a toggle or pushing a button. The power that runs the fuel pump is separate from the power that causes the contacts in the relay to close (and make the fuel pump turn on). I know that's not very clear, but I hope that helps...anyone else wanna try?
summit racing
Can i hook the oil pressure switch to my external oil filter. It has a spot on the bracket that i could use for the switch. This should have preasure here.
Good Luck!!
The block where there is like a 1/4" plug? I have a oil switch but i think i fried it.... Can you blow air into the oil safty switch to make it trip? I had it all hooked up and grounded and i was trying to make it trip the relay but couldnt
my electric fuel pump quite working out on the water. took it off because i thought it burned up after running it off the coil, but it works now when i hook it to the battery. I have perfect 12 volts at my hookup on the boat. Can fuel pumps overheat and then work again?
