How to repair? -FOD to the drive skeg
My non OSO bud tagged a log sometime, broke off the leading edge of the drive skeg, about 1" x 5" worth. It's a 2000 Bravo LWP unit on a stock 502 mag, about 150 hrs so otherwise pretty healthy, light boat (32 fever) with Twins.
The leading edge overlays for recreational boats would do the job but need be the "correct" repair for a performance boat IMHO. So what's the best thing to do, weld a piece in and repaint? Any shops specialize in this? Sterndrivespec?? Is it feasible or is he just better off finding a used lower?
Ginger or Mary Ann?
Do what I did. You can order new skegs (actually just cut offs from factory damaged or defective drives cut right under the torpedo) for approx $25 from BAM and cut out only the area you need to put yours back to original shape. Better than just welding in a peice of aluminum as it is already to shape. Have it welded on,then sand smooth. I then use Marine Tex as a filler over the weld imperfections. Looks like new and can not tell it has been repaired. Much better looking than filing whats left of your drive. Just have to sand the paint off inthe area of the weld. I just sandblasted my both of my lowers and installed all new bearings and seals while I was repairing the skegs. Didn't need to go to the extreme, but figured what the hell.
![Lightbulb](/forums/images/icons/icon3.gif)
I am lucky to have found an awesome welding shop. Alloy welding in Farmingdale NY. I have brought several Bravo lowers to them with the skeg completely gone. I've had them weld up some cases that no other shop, or yard I know of, would consider repairable. I save the uppers that blow up internally and us them to cut repair pieces . The secret in getting it done right is using material that is sand casted and similar in alloy to the Merc. case. This will allow for an easy, strong, uniform weld job. If they fill the case with water, the seals survive. Maybe because I give this shop alot of work, I get better prices. I can't believe how reasonable the costs are. If anybody needs there # PM me. They make fuel tanks, towers, u-name it. And they are nice people. BBB
i like merc's replacements, the aluminum is purer , and easier to weld. all the replacements that i got were new not cuts. just weld a small piece in and fill low section with weld , grind smooth. easy. i wouldn't cut off the whole skeg for a small repair..
