Which Eagle Crank??? >
Old 12-30-2004, 10:40 PM
Swede's Avatar
Default Which Eagle Crank???
Which Eagle crank for a Gen V block(4.25 Stroke,6.385rods) with 1pc rear main? It looks like they have a regular weight with 2pc rear main which would take an adapter. Or is what they call the lightweight with the 1pc ok for marine use? Crossdrilled or not?
http://www.eaglerod.com/products/Che...%20cranks.html
Swede is offline
Old 12-31-2004, 09:54 AM
GPM
Default Re: Which Eagle Crank???
I would suggest an American made crank, Crower, Callies, who ever, I looked at
three of those Gen 5 cranks everyone of them needed to be ground for the bearings
to work. I would use the Mark 4 with an adapter in case you ever want to upgrade
to an after market block. If you use the Eagle rods get the bolt upgrade.
GPM is offline
Old 12-31-2004, 10:04 AM
Registered User
kevinr's Avatar
I am a WD for Callies, A dragon slayer 4340 BBC runs about 800. plu change. Also they just came out with a better priced crank called Comp Star I will need to call for price ,but my rep said they will be competitve with the Eagle.
kevinr is offline
Old 12-31-2004, 10:17 AM
Registered User
kevinr's Avatar
Dont get the crossdilled, ................on the one piece crank, It requires more weight added to the counter weight (for Internal balance) or you can run a weighted flywheel, which still may require more weight due to the heavier con rods. You can use either cranks. Spend 100.00 for the adapter or 100.00 for the special balance. Check your flywheel because that might be the deciding factor.
kevinr is offline
Old 12-31-2004, 11:41 AM
I hate the winter!!
Vinny P's Avatar
Go for the Callies crank. They are better quality than Eagle.
Vinny P is offline
Old 12-31-2004, 12:41 PM
ratman's Avatar
i spoke to several reputable engine builders nd they all agreed that eagle cranks have a LOT of quality issues. the eagle rod are fair but spend a few more dollars and get manleys or another american made. its worth the extra money to buy top shelf bottom end components. the calles dragon slayer cranks shouldn't cost a whole lot more than the eagle. just my .02, ratman
ratman is offline
Old 12-31-2004, 12:50 PM
mcollinstn's Avatar
Why would you want an Eagle-san?
mcollinstn is offline
thedonz
Wanted
4
06-07-2008 09:39 PM
RUSSSR1
9
05-21-2005 03:34 PM
merlin540
07-25-2003 04:53 PM
razor1115
0
08-05-2002 03:18 PM
traviss
8
03-06-2002 12:26 PM
Quick Reply: Which Eagle Crank???
