Holley Marine TBI Fuel Injection
![Post](/forums/images/icons/icon1.gif)
Miguel- I know a lot- I do mean a lot- of people who have tried Holley's various systems on all types of Jeeps with every conceivable motor swapped in- lots of problems, most people take them off and use factory chevy TBI or even go back to carburetors- they were that bad. I suppose they could have worked the bugs out in the mean time but I know of no one with positive experience. Also the O2 sensor is an issue on wet exhaust uless the system does not use one. Good luck whatever you do.
Diamond Member #001
Check with www.flagshipengine.com www.keith-eickert.com or call Innovation: all of them build injected motors in lots of different configurations.
[ 01-17-2002: Message edited by: C_Spray ]
![Thumbs down](/forums/images/icons/icon13.gif)
Had one of the older style - They both use the same tbi unit and I believe both are rated it 500 HP max. Worked great to replace a HOLLEY carb - infinitly adjustable while your running. O2 sensor will have to be placed in the exhaust where it is dry. When they say MAX HP that is it and no more. Raising fuel pressure won't help much as they are low pressure injecters.
