1990 Baja 320
1990 Baja 320
I am looking to buy a 1990 baja 320, can anyone please give me their 2$ on this boat.
Good or bad I'm looking for information. I'm coming out of a 1996 baja 252
Looking for a good boat for the family. do most of our boating between lake Huron and
lake st.Clair. what is average speed of this boat with 454 mags,
not sure of prop pitch.
Re: 1990 Baja 320
The "320" is a totally different boat with a rounded deck and integrated swim platform.
Which one are you speaking. May I humbly suggest the earlier as I believe it is the best boat Baja made and I have owned 2 of them.
JC Performance Engines
Charter Member #927
Re: 1990 Baja 320
Then the swim platform is included in the length, which means it will have a 30' running surface. It's not a bad boat but, the 32 Outlaw would be a little better in rough water. I'm not familar enough to know of any certain problems. It should run close to 70 top end.
Re: 1990 Baja 320
454 mags should make it run low to
mid 60's
It probably has either 23 or 25 pitch
mirage props.
It's an ok boat, but the 32 force, magnum, caliber, outlaw,
flat deck ( whatever you chose to call it )
in my opinion, is a beter boat.
jt
mid 60's
mirage props.
jt
Charter Member #927
Re: 1990 Baja 320
Maybe you are right about the speed. I was comparing it to my 34' Super Hawaii. It has a 32' running surface and with 454 Mags I can just get to 70 with 25" mirages.
Re: 1990 Baja 320
The Boat Is From Michigan ,at Lake St.clair This Boat Is In Showroom Condition With Only 470 Hours. I Had It Surveyed And Scored 9.8 Out Of Ten.
