Hull problem???
Re: Hull problem???
Ya know, my standard response to porpoising questions is that boats don't porpoise, skippers do. I've always had luck finding the right combination of tab trim and drive trim for conditions. I can make a boat porpoise or stop porpoising.
But this thread makes me think that Kenny knows what the heck he is doing, and still has problems.
Huh. Guess I've been kinda lucky.
Re: Hull problem???
Anyone can stop porpoising - trim in the drives or lower the tabs, sure....but both actions add drag and kill speed. Porpoising is simply the hull/trim setup creating more lift on the hull than the power can hold up....so at that given hull/trim setting either more power or less bow lift is needed.............
Re: Hull problem???
Originally Posted by articfriends
Kenny,how loud is your boat? I imagine you must be running dry exhaust with that big ol cam. I have lightning headers on mine and the molded swim platform seems to muffle it alot,at least from the drivers seat!How tall of a prop have you tried,with the kind of torque your making i'm surprised your not spinning a 30 or 32 pitch,Smitty
I used to yell at the ole lady runnin on plane until I put the shotguns on, now we can talk to each other. I kinda liked it before , could not hear any *****in! If your not familiar with CMI's they mix water right at the tails. I'm still messing with props, I'll find the right one one of these day's! I feel once I can get the hull straightened out, it will be easier to ook up the right prop!
Re: Hull problem???
Re: Hull problem???
Originally Posted by kennywould
Tried most everything, I can stop it from porposing with the tabs, but it kills my top end by 2 - 3 mph, if I pick up the tabs I pick up the speed, then the nose starts bouncing. I felt the trim tabs were put on there to plane the boat easier, or keep it planed at low speed, not to hide a hull problem, IMO.
SUPER AIR
15
07-13-2006 09:10 AM
