How much HP can "new" Bravo's >
Old 01-10-2005, 06:27 PM
RLW
Default Re: How much HP can "new" Bravo's
Originally Posted by Back4More
Just make sure you prop it on the back side of the TQ curve at WOT.
Could you clarify?
RLW is offline
Old 01-10-2005, 08:41 PM
offthefront's Avatar
Originally Posted by RLW
Could you clarify?
yea do that ...
offthefront is offline
Old 01-10-2005, 09:03 PM
I think what they are saying, is that big props.are hard on the drives.
HighPriority is offline
Old 01-10-2005, 09:33 PM
jaroot's Avatar
skunkworks there scottyboy????
jaroot is offline
Old 01-10-2005, 09:40 PM
Scott B's Avatar
You saw the boxes..
You knew I'd unwrap em..
Then what did ya think I was gonna do???
Scott B is offline
Old 01-10-2005, 09:49 PM
The TRS drive is a good old drive..can handle power and abuse...you can put the 600 on it with no problem. Back in the day they used to put more power than that on them racing and drive failure was never a issue..never!
Byrdman is offline
Old 01-10-2005, 09:58 PM
Back4More's Avatar
If you prop your WOT rpm too low or too close to your TQ peak of the motors it will tear up the drives that much easier.
Back4More is offline
Old 01-11-2005, 06:42 AM
Jassman's Avatar
Originally Posted by Troutly
What, are ya new!?
I knew someone was going to catch that, I should have guessed it would have been you The hard part was trying to dock, waiting for rpms to come down.
Jassman is offline
Old 01-11-2005, 10:16 PM
Scott B's Avatar
If you like that, try docking a Donzi Blackhawk
Scott B is offline
Old 01-12-2005, 09:48 PM
Higher pitched blades = flatter smack on the water when not sync'd with boat speed/rpm. Lower pitched=slice into the water easier no matter the mismatch. Add to that the more direct route of the power to the water on a high pitch as opposed to the "buffer" of more gear ratio from a small prop. Add to that the need to flog big props to get out of the hole. But hey,you can't beat the cruise speeds.
cooltoys61 is offline
Quick Reply: How much HP can "new" Bravo's
