Retrofitting a pad to an existing hull...
Is there any on-line guidance on how to retrofit a pad to an existing v-hull? I'm a good fabricator - lots of one-off work - so I'm not worried about the structural issues. I'd just like to find some common sense guidance or rules of thumb to design and retrofit pads.
Thanks...Steve.
Thanks...Steve.
Re: Retrofitting a pad to an existing hull...
the rule is its like ur women if you don,t like her bottom then its time to upgrade to one u do like..... other wise you will kill the resale value if you start grinding and glassing .....u can also create one ill handling beast that behaves badly.....or at best is unpredictable
Originally Posted by CMG
If your thinking bottom pad - it'd be easier to install a helicopter pad.
Chris G.
Chris G.
Thanks...Steve.
Thanks...Steve.
doesnt legend have it that Reggie attached a pad of his own design to the bottom of some Excaliber molds that he bought to create the first Fountain.......??
somebody around here should know this.............doug
