Parts Needed
Re: Parts Needed
So that bushing replaces the other one totally. Do ya have to press out the old one out ? I guess the cone goes on top of the bushing then the fiber washer? the washer looks to small for the bolt, may the the angle of the pick.
I figure the spring washer goes flat after your torque the bolt anyway. and they wanted some movement there with the engine alignment ?
Rob
Rob
Re: Parts Needed
The fiber washer goes between the inner plate and the flywheel housing. The only purpose I can figure is to prevent metal to metal contact, possibly with enough engine torque, or the bushing slips out of postion, or fails.
Re: Parts Needed
Originally Posted by Mbam
There is a replacment kit, elimimates the use of the old spring washers, you need 1 kit per engine. Part number is 865329A02, we sell them online for $29.53 per kit (and have them on the shelf).
Marc, I see they have eliminated the spring but does the small stainless washer go in its place?
Kurt
