8.1 Knock Sensor
I need to replace the missing knock sensors on my 8.1 and mercruiser uses a two wire knock sensor with a stud to the block while GM uses a typical single pin sensor does any know if the gm sensor can be used in place of the mercruiser which is about 4 times the gm sensors.Thanks Jeff
