Tail Pipes For Stellings
I have these pipes , They were out of a 38 Cougar with speedy's , don't know if they will work for you . I have to measure the dia , I'm not sure what size they are. I had the picture on floppy disk. Tom
Charter Member #40
I have a set of four for sale in the swap section that were off of Stellings Green pipes which were also used on a Speedy boat. Lengths are roughly 31" and 33. You could cut the ends and re-weld without a problem to fit the required length. The manifold should already have the angle drop in it so a straight tp should work.
I have two sets 4.5" straight off a bravo setup, one season fresh water use look new. These have the Merc flange on them. Came off 30' Spectre.
