Why would pink coolant drain out of 496 mag?
Originally Posted by Bilgerat
mg503 is the winner finnally an intelligent answer on this site.
I guess I am only somewhat intelligent?
It's the grommet if it happens over the winter. Count me in, as only my port does this. Filled it up last spring and no problem for the season. I haven't noted if it's run out this winter. I'll have to look the next time I'm over in the building.
I filled the coolant back to fill line on Fri and it all ran back out over the weekend. It was 65-75 degrees this weekend, so I thought it might seal up. I think I found the gromet on the left if you're facing the front of the motor. What's the trick in removing the heat exchanger and does it just sit down into the rubber grommet without loosening or tightening anything? This small little stuff like this sucks.
![Thumbs down](/forums/images/icons/icon13.gif)
Ed, I can certainly relate to your frustration. I try to help as much as possible on this site, but you always seem to have some smart a$$ come along and think their cute. I still need a little help with my problem and any advice would sure be appreciated...
![Smile](/forums/images/icons/icon7.gif)
Mercury Marine had some problems with the grommets under the heat exchanger on the 496's developing leaks after sitting and use. I believe they had a recall through the Mercury dealers to repair them with new grommets. Check with your local Mercury Marine dealer or your boat builder. Hope this helps.
Ray @ Raylar
Ray @ Raylar
