What is difference 502EFI / 500HP? >
Old 02-07-2005, 11:37 PM
Ginger or Mary Ann?
US1 Fountain's Avatar
Default Re: What is difference 502EFI / 500HP?
Originally Posted by khadley
they are the same
no billet rods
Wasn't sure. It seems like last yr someone posted pics of their rods from the500EFI that had 'Mercury Racing' etched into them.
US1 Fountain is offline
Old 02-08-2005, 07:47 AM
jdnca1's Avatar
I thought I saw that also US1, I think it was strip poker. His motors had been apart before as I recall and many things were not "stock merc".
The rods in my 00' 500EFI's are stock GM, per seeing them last weekend.
jdnca1 is offline
Old 03-09-2005, 05:05 PM
formula377's Avatar
Isin't a 502Mag MPI what we are talking about? 502 EFi same as a 502 Mag MPI?
What is the difference between just the FI systems?
formula377 is offline
Old 03-09-2005, 05:08 PM
offthefront's Avatar
75 hp ?
offthefront is offline
Old 03-09-2005, 05:28 PM
formula377's Avatar
When people say EFI are they speaking about the HP500EFI system? And 502MAG would be the MPI system?or are there other systems?
Is one an open or closed loop system? What makes either system better?
Old 03-09-2005, 07:29 PM
Ginger or Mary Ann?
Found it. These are in the classifieds by Fountianclimber out of a 500EFI
Old 03-09-2005, 07:45 PM
mcollinstn's Avatar
Yep.
Rods were new for '02 I believe.
mcollinstn is offline
Old 03-10-2005, 05:02 PM
MarineKinetics
rmbuilder's Avatar
Indy,
Cam specs for 502 MPI:
288*/288* seat
224*/224* @.050"
.483"/.483" valve
115.5* LSA
109* ICL
122* ECL
502EFI:
292*/298* @ .004"
230*/236* @ .050"
.598"/.610" valve
114* LSA
109* ICL
119* ECL
502HP:
284*/292* @ .004"
222*/230* @ .050"
.576"/.598" valve
110* LSA
105* ICL
115* ECL
Bob
rmbuilder is offline
Old 03-11-2005, 07:35 AM
IndianaHeat's Avatar
Differences between the two per Merc.
Precision CNC machined 502 C.I.D. cast iron cylinder block.
Forged 4340 steel, fully machined and shot-peened Mercury Racing connecting rods.
Forged aluminum pistons, designed by Mercury Racing, for maximum strength and durability.
MEFI 3 Electronic Control Module digital ignition system features advanced electronics for more precise fuel and spark control along with better top-end throttle response.
Multiport fuel injection system incorporates a high-flow throttle body and tuned intake manifold developed exclusively by Mercury Racing.
A thermostatically-controlled, high-capacity oil cooler raises engine oil temperatures faster and keeps them more consistent.
The oil thermostat and a Positive Crankcase Ventilation (PCV) valve work together to reduce the buildup of condensation in the oil. The PCV valve also improves engine idle.
A hydraulic roller camshaft, which improves low-end torque, offers higher level of performance and aids fuel economy.
IndianaHeat is offline
Old 03-11-2005, 07:48 AM
formula377's Avatar
rmbuilder
Is the 502EFI and the 502HP that you just described the cams for, what mercury calls their HP500 engines?
Quick Reply: What is difference 502EFI / 500HP?
