adding K planes
I have a 29 powerquest with twin 7.4 mpi the boat chine walks at speeds over 50-55mph
it came with insta trim 12x13 dual cylinder trim tabs.I have heard that there to small for the boat and the manufacturer uses them because of price.
I do have a set of K planes 14x19 do you guys think I will notice any difference if I install them or would I be wasting my time.
http://www.martiniboatmarinedesign.com
Contact Brian at the above link. He probably has just what you need.
Trim tabs might help, but I think you have issues somewhere else. Take a look at your steering setup(cables, pivot points etc) and also prop rotation (spinning in or out) Also check your drive toe in.
How do you check and set the outdrive toe?
