Piston Sprayers
Re: Piston Sprayers
Originally Posted by cstraub
B&B, Joe Stef bought B&B 7 years ago. So B&B are out of the same facility in Lakewood, NJ. I work from home in TN.
Chris
Chris
So Chirs what kind of work you doing from the house now?
Rob Stringer
Re: Piston Sprayers
Rob,
If you were WD with B&B then you are grandfathered in with B&B with some stipulations. You can e-mail me for details. No Jeff at the shop. Stef's purchased B&B to compliment the Stef's line.
The B&B line has expanded into locks, retainers, studs, and other cylinder head components. This is my background, design, marketing, and tech support. Joe was wanting to grow the line and I was looking for a change, so it worked for both of us. . .with one condition: this southern boy wasn't movin' to Jersey!!!
Camshafts are a hobby of mine and have been fiddlin' with them for several years now.
Chris
Chris
Re: Piston Sprayers
Originally Posted by CcanDo
Laz,have you seen much pressure drop with needle cam bearings?How do you feel about lifter bushings?and,what about solid push rods? In case someone is considering piston oilers,you may want to ask laz before you do!
Registered User
Re: Piston Sprayers
[QUOTE=Strip Poker 388][IMG]
You dont find many people doing this ,just the higher end guys Crower cals theres Inrad cams.
That is true, when I see Laz working on this machine he is their for a long time. It takes alot of skill to do this and Laz does it for alot of engine builders in our field around the 48 states. When in doubt call Laz and he will walk you through any task when it comes to machine and engine building. Their is not one machine that Laz does not have to do any type of work, it is all in house.
Re: Piston Sprayers
I was surfing the tech section when I stumbled across this thread.
Piston oilers sound like a great idea for supercharged engines. Keeping the piston cool should help delay detonation all things equal? What about coating the piston? If you do cool the pistons enough will you reduce the amount that they expand and have to change clearances? Who has done this on a supercharged engine and seen increased life and/or detonation protection? Would you talk about it if you had success in this area?
Re: Piston Sprayers
RMbuilder,that's correct.Now,we need opinion on orifice diameter of the spray nozzle.The question is;should the diameter change from wet sump to dry sump?
