How long should it take to remove/re install engines?? >
Old 07-20-2021, 11:19 PM
  #31
Hi Waterboy,
What was the resolution to this? I think I might of just had a similar experience, except i am even further north of your hours, was yours in NZ?. high level mine was
remove 2x engines,
replace transom assem including exhaust horns
replace fuel system on engines while out
water pick ups replaced
A bit of bilge tidy up, wiring etc
bilge pumps replaced
drive coupler,
thermostats x2
spark plugs and leads.
re install
run up test while on the hard.
A couple other things like exhaust flapper, starter motor, alternator.
i got to the a grand total of 160hrs
Plus i had someone else do the steering refresh.
there was a long wait on the hard as parts took along time to arrive. my expectations was maybe upto 3 days to get motors out, maybe 5 days to do the engine fuel work + bilge and water pick ups, 3 days for engines to go back in, and 1 day admin, which gets to around 100hrs. given the comments here that seems to be taking the piss a little? 160hrs seems utterly insane.
interested to hear what your resolution was?
mawfun is offline
Old 07-21-2021, 05:22 AM
  #32
Originally Posted by mawfun
Hi Waterboy,
remove 2x engines,
drive coupler,
thermostats x2
re install
This must be some kind of a record. The post is only 16 years old!
HawkX66 is offline
Old 07-21-2021, 06:40 AM
  #33
Talking
Originally Posted by danny_ocean
that's an insult to wheelchair-bound mechanics everywhere. Someone in a wheelchair could've did it in less than half the billed hrs!
if given 101 hours (and a high iron diet), i could probably poop a long-block.
d. Ocean
miami, fla
lol
Poker Face Xtreme is offline
Old 07-21-2021, 04:23 PM
  #34
Received 4,864 Likes on 1,376 Posts
I can let you know borrow my helpers, they work for sun and alcohol
ICDEDPPL is offline
Gimme Fuel (07-22-2021)
Old 07-21-2021, 05:15 PM
  #35
jeff32's Avatar
with those helpers i would hope for engine problem each week end !!!
jeff32 is offline
JB4Boyne
Baja
7
05-11-2008 06:32 PM
LubeJobs42
02-29-2008 10:38 AM
lv92780
Drives and Lower Units
7
07-04-2007 08:38 PM
customryder
05-15-2006 09:22 PM
phughes69
18
06-30-2005 11:20 AM
Quick Reply: How long should it take to remove/re install engines??
