hp 500 cam specs ?
MarineKinetics
Both have 5* adv ground in.
The wider spread of 114* in the EFI, compared to 110* Carb, keeps the overlap to within 1* of each other (68* carb vs 67* EFI) even though the EFI has 8*/ 6* more seat duration. Maintains signal strength. The IVO/ EVC are nearly identical (1*) ,the EVO/IVC are 7*/ 8* altered.
Bob
Bob
Does anyone know if this is a good swap in a 502/415 MPI ?
Been looking a bigger cams and one manufacturer had said they had one that was similar to the HP500.
