Cheap upgrades - Exhaust mainifold swap?
Re: Cheap upgrades - Exhaust mainifold swap?
Exhaust will not give you any more speed! So many have spent good money on exhast only to get nothing, except different sound. What boat do you have? Give some details, there may be better places to spend your money.
Unless you are only looking for a deeper rumble sound, and want to dress up your engines in appearance then I would have to agree that there won't be much bennefit in performance from switching from a stock Merc cast iron exhaust system to an aftermarket exhaust system on a stock engine. However, if you plan on upgrading your engine(s) either now or in the future then you WILL benefit from an aftermarket exhaust. The more mods you do to the engine, the more an aftermarket exhaust system is going to bennefit you in performance. If this weren't true then many of the boats and their engines you see these days would NOT have a better breathing exhaust system than the stock Merc cast iron exhaust manifold.
I used to hear a term long ago, and it went something like this; "There's free horsepower in the exhaust." I don;t think it is exactly free when it comes to marine exhaust systems, but there is power to be made from the exhaust for sure.
JC Performance Engines
I did the exhaust cause i am rebuilding my engine and don't want the problem i had w/ the stock manifold. But since I did the exhaust, I might as well upgrade the engine components, equating in more HP, needing the better exhaust. Its one big happy circle.
Check with one of the prop sponsers here and see if they think some MPH can be gained with a diff. prop, or modifying the one you have.
I have to respecfully disagree. With my old STOCK SBC in my formula I gained a 2mph. This was going from stock thru hub merc manifolds to thru-hull Stainless Marine. A good alternative is to go with imco risers with your stock Merc manifolds.... GLM also makes VERY good replacement maniflolds for the merc ones. I belive they are about 1/2 the cost of Mercs......
BH
BH
BH
