four winns liberator speed ? >
Old 02-17-2005, 05:01 PM
Default four winns liberator speed ?
i am putting a 575hp 502 in a 241 liberator and am looking for a realistic speed to expect thanks with bravo
dodsonartic1 is offline
Old 02-17-2005, 05:11 PM
Toxic FORMULA
mopower's Avatar
Default Re: four winns liberator speed ?
I had a 211 with a 340hp 460 Ford did 61/62. Replaced it with a 625/540. No GPS at the time , but stood an 80 mph speedo straight down
My guess would be upper 60's perhaps 70 on a cool dry day.
(I'm pessimistic so not to be disappointed)
Another way to look at it is 3 to 4 mph per 100 hp gain.
mopower is offline
Old 02-17-2005, 09:29 PM
I have an 87 241 with a 540, 585hp, 615ft lbs, spinning a labbed bravo 26p 4900 rpm 65mph. I want to try a mirage plus 25 or 27. My drive is too deep, I was told a mirage will let me hit 5500Rpm and 70mph. GPS speeds here.
Lets see pics of your boat, Id like to hear more about it!
MILD THUNDER is offline
Old 02-17-2005, 09:56 PM
I'm running 60mph in a 211 with a stroked small block, and a 21" SST Viper on an OMC Cobra drive, and just me in the boat.
Liberator21 is offline
Old 02-18-2005, 07:41 PM
FOUNTAINATLAST's Avatar
I feel you should see realistic speeds of solid low 70's. I had a 90 221 Liberator with a 454HO set of EMI Headers, small cam increase, Aluminum Intake, & MSD Ignition. After Lengthy prop testing I found a consitent 67 on a gps speedo. I'm not sure of HP specs but I'm guessing I was arond 450 after mods??
FOUNTAINATLAST is offline
Old 04-22-2006, 06:58 AM
fountainatlast- what kind of prop were you running with the 221?
swood5991 is offline
Old 04-22-2006, 10:18 AM
markt111's Avatar
I had a 211 libbyy and loved it, couple notes for you...Mine had a built in rocker in the hull, if your looking for speed this may be something you want to get rid of?? but it may affect the ride?? best prop on my hull was a Ballistic, tried them all Mirage, Bravo, Viper etc...
markt111 is offline
Old 02-27-2011, 10:25 AM
I have a 93 librator 221 with 502 omc with motor work. lighting tubular headers, roller rocker arms, victor jr. intake com cam 4800 to 5500 rpm. im thinking its around 500+hp. Im running the stock prop 141/2 x 20 . speed before motor work was 62mph on a good day, now after motor work my best is 64mph on ruff water. I want to get more out of it . whats the best prop for the liberator?
intimidator is offline
Old 02-27-2011, 11:07 AM
Welcome to the site !!!
This thread is 5 yrs old, you may get more responce if you start your own thread. There is also a section here just for props you can post on.
jeffswav is offline
Old 02-27-2011, 10:05 PM
I used to have a 251 Liberator and was running a OMC Viper prop. For the latest in prop design you need to get a Merc prop with the Flo-Torq hub system so you can run Merc Props on a Cobra drive.
A 23" Mirage plus or a four blade Bravo 1 prop should help you a lot
rexcramer1 is offline
Quick Reply: four winns liberator speed ?
