OOpps.Lean wasn't mean
Rob
I was at my Buddy's machine shop and this piston had a new bung hole
These easy money guys had leaned on it and detonated the motor so it started burning oil in 3 & 7 so they thought the NOS was rich in those holes because it was blacking those plugs , so they leaned out the those 2 holes .Ooops . Another DumbA$$.dot com guys. the funny thing the car had data acquisition and exhaust temps .
What I thought was weird the piston looks like it only maybe .250 think on the top .Thin
The guy that builds there engines{he has spares] is a X Nascar engine builder .
I guess the piston is in the upper 400 grams
![EEK!](/forums/images/smilies/eek.gif)
Rob
Ck out the replacement . Oh yea they started ordering the spare piston in set of 10
Not much of a skirt, pin is in the oil ring, gas porting, the valve reliefs look kind of canted(big azz too).. hmmmmm..I'd guess stroker small block? Do tell!
Rob
Originally Posted by Sonic30ss
Not much of a skirt, pin is in the oil ring, gas porting, the valve reliefs look kind of canted(big azz too).. hmmmmm..I'd guess stroker small block? Do tell! ![Big Grin](/forums/images/smilies/biggrin.gif)
Big /big block made around 1300hp.I will try to get some more picks and info.
Looks as though thr head gasket was a problem below the bore. water may have intensified the problem?
47 Lightning SE
47 Lightning SE
