Closed Cooling Question >
Old 02-25-2005, 07:46 PM
CPPerformance's Avatar
Default Re: Closed Cooling Question
Originally Posted by skaterboy
Suggestion: add header drains so you do not have to flush headers. All salt water will drain from the bottom of the headers when the engine is turned off.
This would be a bad idea in our opinion. By simply draining the headers without flushing salt is going to crystalize in the header and build up over time. This would have the potential of blocking passages within the header.
If you've seen a full cutaway of either a tubular header like CMI or a cast manifold like Gil's you would notice that the actual water passages in some areas are very small so it would not take much of a build up to cause a blockage.
If a blockage were to develop you would then have hot spots in the header which would lead to premature failure.
If you're going to drain the headers after each use which is highly recommended, you should first flush the system completely and preferably with the use of a product such as Salt-Away to neutralize and remove the potential of salt crystals forming within the system.
Hope this helps, if you have any more questions just ask!
CPPerformance is offline
Old 07-06-2009, 01:21 AM
When you have an over heat issue in these systems what are the usual culprits to check out?
damon is offline
BZ
5
04-25-2007 09:48 AM
sandcraft
10
04-05-2006 09:44 PM
Mike Paula
4
01-27-2006 10:40 PM
chrisf
01-14-2006 11:31 AM
Chris288
14
10-29-2004 02:13 PM
Quick Reply: Closed Cooling Question
