Less speed but better handling
#31
TJ I didn't consider the clearance issue. Sure 6'' will help but only 1/2 as much as 12'' is it worth while? That is up to you. Why don't you figure out the cost of changing to a 6'' setback and then consider either a set of sponson tabs or a tunnel tab. Can you current bracket be modified or will it need to be replaced?
Try the props first and add some weight in the bow, then if that is not enough you will have to decide where to spend your money. My opinion is that the props will help the boat plane faster but you must change the balance of the hull to limit the bow rise either by moving weight or by installing trim tabs.
#32
Thanks, TJ
#33
Originally Posted by Steve Zuckerman
tj,
A friend of mine here in Nashville, Mike Ray, makes great ride plates. To see his stuff and/or contact him go to www.bulletowners.com and click on links.
Click on Mike Ray's foils and skid plates. By the way, these products do work.
Regards,
Steve
Regards,
Steve
Thanks Steve...TJ
#34
TJ It only makes sense to try the easy things first. If you find you need a tunnel tab let me know. I may be able to hook you up with a used tab. Keep us informed how things work out.
Good Luck Michael
Good Luck Michael
