I'm in need of advice on replacing a cracked 502 MPI 1999. >
Old 03-01-2005, 07:11 AM
offthefront's Avatar
Default Re: I'm in need of advice on replacing a cracked 502 MPI 1999.
wonder how good these guys are .....not bad price ....
www.1800runsnew.com
632 10.36 L 725 hp "Attack Dog II"
$10,650
A stroker forged nitrited steel crank is used with Eagle H-Beam connecting rods and J&E flat top pistons with Speed Pro plasma moly rings. World Products Merlin rectangular port heads with Manley stainless steel valves are used with Crane roller rocker valve train and Crane roller cam. Clevite "77" are the bearings of choice.
Uses Merlin tall block, Lunati forged steel stroker crank, special J&E pistons and all the goodies
Every engine is dyno tested and shipped with its own dyno sheet.
The "Attack Dog" produces 725 hp and a whopping 725 ft/lbs @ 3800 rpm
This Baby will run all day on Pump Gas
offthefront is offline
Old 03-01-2005, 08:27 AM
How much is the boat? You could have that engine same as new for under $2000 if you did it yourself. MPI is totally simple. All of the uniqueness is in the intake manifold. Remainder of the engine is same.
SmallPP is offline
MariahMadness
4
05-18-2005 06:19 AM
Cat-n-Around
2
07-22-2003 05:44 AM
JO - PANTERABOATS
Pantera
7
11-22-2002 01:43 PM
baja bailey
10-22-2002 02:48 PM
JO - PANTERABOATS
Pantera
4
10-18-2002 04:59 PM
Quick Reply: I'm in need of advice on replacing a cracked 502 MPI 1999.
