I'm in need of advice on replacing a cracked 502 MPI 1999. >
Old 02-25-2005, 09:18 AM
East Coast B's Avatar
Question I'm in need of advice on replacing a cracked 502 MPI 1999.
I'm looking at a boat with a cracked 502 MPI and researching motor prices on the web.
I believe that if I buy a base 502, same generation as what I'm replacing, I should be able to just drop it right in and utilize the current MPI top end on the cracked motor, is this correct?
I've replaced a 454 carb engine before, but never an MPI or messed with an MPI, just want to know of any concerns before I go buying a base block? Any recommendations? How involved is installing the MPI? What to watch out for? Want to do it right the first time.
I've seen new base motors going between $5200 and $5700, any suggestions on best place to look? I'm located in Pennsylvania.
Thanks for your help everyone!
East Coast B is offline
Old 02-25-2005, 09:26 AM
Charter Member #232
Audiofn's Avatar
Default Re: I'm in need of advice on replacing a cracked 502 MPI 1999.
check out www.1800runsnew.com. I have heard nothing but good about those guys. They should be able to help you out with any questions that you have.
Jon
Put your best foot forward!
Audiofn is offline
Old 02-25-2005, 09:59 AM
SeaRay Jim's Avatar
If it's just the block cracked, you could always buy a new block and set it up. Even if you want to keep it stock, that would give you a chance to blue print the bottom end and put it together right.
Brand new bare 502 blocks go for about $1500
SeaRay Jim is offline
Old 02-25-2005, 03:31 PM
Bare Block... that's a thought too!
Has anyone mounted a MPI? Any difficulties or as easy as putting on a regular carb manifold intake?
Old 02-25-2005, 07:37 PM
I hate the winter!!
Vinny P's Avatar
If the block was damaged due to freezing, I would be very careful about having the cylinder heads, oil coolers, etc. checked for cracks as well. Replacing the block is not that difficult to do. But getting all this work done and then having chocolate milk in the oil due to a cracked head or oil cooler would suck.
Vinny P is offline
Old 02-26-2005, 04:27 PM
TOMMY HIWAVE's Avatar
jassper eng did mine twice
TOMMY HIWAVE is offline
Old 02-26-2005, 04:37 PM
Toxic FORMULA
mopower's Avatar
I've heard Jasper takes a couple of trys
mopower is offline
Old 02-26-2005, 04:41 PM
Our local guy quit using Jasper, just too many come backs.
BadDog is offline
Old 03-01-2005, 12:17 AM
Jasper licks. I rebuilt a motor after them and it had 2 different size valve stems in it on the intake side. Just go through it yourself, and have the heads, intake, and exhaust checked for cracks. It's not that expensive. New block, rings, bearings, oil pump, and seals and your back in the game.
SmallPP is offline
Old 03-01-2005, 06:54 AM
offthefront's Avatar
Ditto on that Sheit .....
offthefront is offline
Quick Reply: I'm in need of advice on replacing a cracked 502 MPI 1999.
