Vinyl upholstery cleaner
Re: Vinyl upholstery cleaner
Most grocery stores,Walmart and I think home depot carry the erasers. You should pick up a couple and try them around the house...they are awesome.
Zippo Lighter Fluid Is Good To Remove Spots/grease Etc. Use On A Small Area To Remove The Spot, Rinse With Soap And Water Then Use A Protectant With Av Protection.
I use Clorox cleaner with bleach. 6 yrs and no problems with the stitching. Spray it on, scrub a little to get superclean and dry with towel.
Before you try anything harsh, try Murphy's Oil Soap. It has worked well for me and should not hrm fabric or stitching. If that does not work you haven't ruined anything and can try something else.
I had a boat with a mostly white interior that had mildewed some. I used Full Timer's Choice R.V. black streak remover. It worked EXCELLENT!!! It also cleans the hull very well..
You can get it pretty cheap at wal-mart in their automotive/rv section.
Doug
Doug
