Can I use a tall oil filter on a 502 Mag MPI? >
Old 03-15-2005, 10:16 PM
Received 1,932 Likes on 971 Posts
Default Re: Can I use a tall oil filter on a 502 Mag MPI?
I moved mine on a '93 454mag to the transom. Made a bracket out of 1" angle steel, drilled it for the remote mount and screwed it to the transom. Original oil lines worked fine.
Griff is offline
Old 03-16-2005, 09:08 AM
CObarry's Avatar
Originally Posted by Pismo10
The Mobil 1 M1-302 will definitely not fit the 454/502 Mag with the remote filter mounted on the exhaust, unless late model enough to be upside done. Which Mobil 1 filter will fit? Which Mobil 1 filter is the same as the M1-302 but shorter?
M1-111 is what I've been told. I looked at one, and it is TINY compared to the 302. I've got to find a way to move the mounting.
CObarry is offline
Old 04-19-2005, 03:17 PM
The M1-111 Mobil filter is the short replacement for the M1-302. It is TINY.
Pismo10 is offline
marwan
7
11-05-2008 01:22 PM
Thunderstruck
8
03-03-2008 07:14 PM
trawfish
4
12-12-2007 11:36 AM
blownboat
11
04-19-2004 09:08 AM
CigDaze
3
09-30-2002 07:13 PM
Quick Reply: Can I use a tall oil filter on a 502 Mag MPI?
