How Much Intercooled Boost Can Be Run On 9.5 Comp Ratio >
Old 03-17-2005, 12:07 AM
Default Re: How Much Intercooled Boost Can Be Run On 9.5 Comp Ratio
Originally Posted by thunderusone
What difference does the specific gravity make if the fuel is pressurized with a regulator? IE you make the same PSI with AV or 93?
This has nothing to do with fuel pressure.
The higher the specific gravity the fuel is denser therefor the fuel is packed tighter in the same amount of space which makes it weigh more.
Air/fuel ratio is measured in weight therefor a 12/1 ratio will be 12Ibs of air to 1Ib of fuel. So if your carb pulled out the same amount of fuel in volume and it had a lower specific gravity there would be less fuel for the air that passed the booster. Then the only way to correct this would be to add heavier fuel or increase the jet size.
It is important to know your specific gravity when tuning because .01 difference in specific gravity usually means 1 jet size difference and if your already on the lean side good luck.
NOBODY is offline
Old 03-17-2005, 03:40 AM
Off the Radar
Linster's Avatar
Originally Posted by FASTERDAMITT
If I want to put a Whipple or Procharger on a 9.5cr 572 carbed engine, how much boost can I run on pump gas? I'm thinkin 3-4#'s.
I would suggest you follow your thoughts. I did a 572 with 9.2cr, ran 4.5 lbs with just 93 fuel and its still living. Watch the timing and keep the heads cool. A 26 Velocity went from 86 to 98 GPS. Had to go up quite a few jets to get the plugs looking good from a normal blower carb setup. He still stops at every fuel station, but gets there quick.
Linster is offline
Old 03-17-2005, 08:10 AM
It's not all just the Specific gravity of the fuel, there are other factors.
That being said we'll look at Nobody's example. As fuel gets hotter it looses some of its high end additives, and the Specific gravity gets lower. If you had your engine calibrated to run with a fuel at .750 SG, and it dropped to .680 SG. That is a change of about 9%. That change moves with the flow area of a fuel jet. Bottom line meaning if your carburetor had # 90 main jets in it with fuel at .750, and the fuel got to .680 you'd have to go up to a #93 or #94 main jet. Big change!!!
Rich as safer!!!
RumRunner is offline
Old 03-17-2005, 04:56 PM
thunderusone's Avatar
Does this hold true for regular race gas...this got started talking about AV gas.
thunderusone is offline
Old 03-17-2005, 07:55 PM
Very much so.
When you buy or look at the web sites that sell or manufacture the fuel they should list the specific gravity for the model number fuel they sell. If they don't all you have to do is call and ask them what it is.
Here are some examples:
Sunoco-111---------.725
Sunoco-112---------.715
VP RED--------------.742
VP C12--------------.710
VP C14--------------.690
VP C16--------------.730
AV GAS between---.650 and .700
93 pump fuel average .750
NOBODY is offline
Old 03-17-2005, 08:37 PM
A to Z
Sean H's Avatar
i think i would go with rum runner on this....
Sean H is offline
Old 03-17-2005, 10:04 PM
Nordicflame's Avatar
PM Bobl...
He is currently working with Dustin on a 565 with 9.4:1. Appears the cam is a big savior here also. He can give you the details.
Nordicflame is offline
Old 03-18-2005, 10:39 AM
FASTERDAMITT's Avatar
FASTERDAMITT is offline
CcanDo
18
08-17-2008 10:34 AM
jryan26
3
07-10-2006 01:38 PM
1BIGJIM
15
03-16-2006 12:33 PM
eliminator219
2
02-15-2004 11:44 AM
Allan4
39
12-12-2002 01:37 PM
Quick Reply: How Much Intercooled Boost Can Be Run On 9.5 Comp Ratio
