whats the best brazing rod 4 the oil pickup >
Old 03-23-2005, 07:00 PM
ratman's Avatar
Default whats the best brazing rod 4 the oil pickup
was wondering what flux and brazing rod is the best for welding the oil pickup to the pump? thx, ratman
ratman is offline
Old 03-23-2005, 08:11 PM
GPM
Default Re: whats the best brazing rod 4 the oil pickup
Tig it.
GPM is offline
Old 03-23-2005, 10:37 PM
mcollinstn's Avatar
sil-phos and dry acid powder flux should work well.
or you can Tig it.
mcollinstn is offline
Old 03-24-2005, 06:47 AM
KNOT-RIGHT's Avatar
Tig with a Silicon Bronse rod.
Dont forget to remove the spring.
Dont want to heat it up.
This is what mine looked like before I hacked it up.
KNOT-RIGHT is offline
Old 03-24-2005, 06:59 AM
excursion's Avatar
Contact , Linster hear on the board, he brazed both of mine on. Works really well and seals it up tight.
excursion is offline
Old 03-24-2005, 06:06 PM
Registered User
kevinr's Avatar
I tig all mine with special weld rod made to blend un similar steels and cast iron together
kevinr is offline
Old 03-24-2005, 07:36 PM
I have done tons with steel wire Mig. None have ever come loose. Do not braze!!! Note: only use new pickups.
Andy is offline
Old 03-24-2005, 09:27 PM
ratman's Avatar
thx andy i have a mig welder but brazed em instead they came out just fine. i used brass rod flux coated.
ratman is offline
Old 03-28-2005, 03:44 PM
I've had both ways fail. I always weld a strap to the pick up and bolt that to the pump.
kennyo is offline
Old 03-28-2005, 03:54 PM
ratman's Avatar
my pickup have that strap already, but thx for the heads up, ratman
ratman is offline
Quick Reply: whats the best brazing rod 4 the oil pickup
