SSM 2's or 3's
Can anyone tell me what drives these are or how can I tell the differnce from a 2 & 3.
http://www.ldeo.columbia.edu/~mvitel...in/1259849.jpg
or
http://www.ldeo.columbia.edu/~mvitel...n/PCDV0038.JPG
mike
or
mike
These definitely look like SSM II's based on the size of the upper housing, and the fact that a small diameter prop fills it up to the cav plate. Also, the trim rams are way too small in diameter to be III's
To be sure, check the serial numbers:
SSM II older than 1985:
serial numbers up to Z2021212C where the first letter indicates the gear ratio
or after 1985:
serial numbers A 544504Z using the last letter as the gear ratio.
SSM III's:
Z38022378C through X38092085C where the first letter is gear ratio
or
A568120Z where the last letter is the gear ratio.
or after 1985:
SSM III's:
or
I beleive so...ill check the serials today, before auction end.
http://cgi.ebay.com/ebaymotors/ws/eB...ADME:B:EF:US:1
