Rev Limiter Question
Are we having fun, yet?
Re: Rev Limiter Question
James, I understand that you changed the cams in your engines. What cams did you install and did you change lifters.
I'm looking at changing mine......
Jay
Jay
Originally Posted by baja36ft
I have a 1999 hp500 that has a rev limiter that i want to remove but not sure how to!!!!!!!!!AND YES IT IS A CARB
Use the standard wire harness that US1 posted a link for.
Keep in mind this will only work if you have a TB IV ignition. Just because its carbed doesn't mean it has a TB IV. If its a TB V then you have to send in the ecm to have it raised.
According to www.mercruiserparts.com the last year of production for carbed HP500's was 1998. They could still be in a 99 boat. Depending on serial # they could have TB IV's or V's.
Also, I see no reason to remove the rev limiter on a stock engine. It is there for a reason and you should prop the boat accordingly. A modified engine may need to spin higher rpms to make its power.
Yes, that is what I am doing. My motors are not in the stock form anymore, my new peak RPM power is at 5500-5600 rpm, could not get there. I was also told that the TB V ignition is preset and CANNOT change the setting. I called Arizona Speed & Mercury Racing dept, they were NO help at all.
Gizmo, we put in a 112 lobe center Crane Cam. I also bored them out 30 over and pumped up the compression to 9.75 / 1 and did change the lifters. Had the heads ported and intake port matched. AED 850HO cfm carbs also.Everything balanced , Few more little things done. Sounds great!!!!!
Check this thread out:
http://www.offshoreonly.com/forums/s...ad.php?t=98792
Now........ get that thing back in the water.
I want to know how those shorties end up working .
No help at all ? I have heard that before
What it the factory rev limiter set at????
Rob
Hey Rob, I called twice too the Mecury Racing department trying too get someone to help me, and both times asked what my rev-limiter was set at and got two different answers
it is either 5250rpm or 5300rpm, but as someone else said theres is at 5350rpm ??????????
I will see today how it works, heading up to a local lake for some prop test.
5 blade 30"
4 blade 31"
4 blade 32"
4 blade 33"
Post results tonight.
5 blade 30"
4 blade 31"
4 blade 32"
4 blade 33"
I too, was under the impression that the rev limiters were set at 5250. There have been several replies that suggest to bypass the limiter. I don't get a warm fuzzy feeling with that idea. So, I did some investigating an found that MSD has a rev limiter ($129.9 list ) that has modules for several RPM ranges. The module kits are $34.99 ea. and have five modules in each kit. example: 5000, 5200, 5400, 5600 and 5800 RPMs. That sounds like cheap insurance, to me.
Jay
Jay
I need to get a pair of them, got a little high today at one point when the boat left the water and spun up to 6000rpm,
Want that as a back up.
Were did you find them at??
If I was going to buy a rev limiter/modules for $150, I would just get a Crane ignition box for It will wire directly into the merc distributor, has most of the merc advance curves built in, and has a built in adjustable rev limiter. I think they are around $300.
