checking fuel delivery system
The vacumn test will tell you if there is a restriction, collapsed fuel line, clogged filter or bad anti-syphon valve. You can also pressure test the system to see if you're sucking air anywhere. Fuel pump pressure should be checked with a pressure guage.
Originally Posted by bowtie
The vacumn test will tell you if there is a restriction, collapsed fuel line, clogged filter or bad anti-syphon valve. You can also pressure test the system to see if you're sucking air anywhere. Fuel pump pressure should be checked with a pressure Gage.
Question it there any fuel pumps create enough vacuum to give a false reading on the vacuum gage?
thanks for the info
Rob
