What should I run
Sometimes the smaller P5 boats combat the waves better than bigger P5 boats, in certain sea conditions. Weight distribution and long k-planes play a big role too.
Litlguys,
Besides horsepower to push the boat, the class will be determined by your max speed based on a prop calculation taking into account max rpm (rev limited), prop pitch and drive ratio. Prop calc is: Max RPM x Prop Pitch x .01 / drive ratio / 12 = max speed
As a few of the guys have mentioned, P5 is probably the best class for that boat. In SBI/APBA, with a 1.5 drive ratio and 5600 rpm you can use up to a 23 pitch prop, at 5400 rpm a 24 pitch prop. I think OPA uses the same prop calc (Jersey Boys please chime in if I'm incorrect).
Glad to see a new boat coming out. Don't hesitate to ask if you've got any more questions. As you can see from this post, a lot of guys are willing to help get someone new started in this sport we love so much....caution though...you will get hooked!
Sean
Sean
Registered User
Sean, you are correct. We do follow the same rules. Prop calc is the same. Only difference up here is if you feel the prop calc doesn't work out on you boat. One of our inspectors will run it with you and adjust prior to the race. You must also have a particular rev limiter mounted in a particular location, with all wiring exposed. We issue rev chips. Smitty
Sorry I haven't been on here guys but theres a good reason, Wed night my project came to a screching hault when I got a phone call that the garage were my boat was caught fire. Total f**king loss everything that was in there is know a pile of ash. Don,t know what the insurance company is going to do, but the show must go on so anyone who knows of 24' offshore hull for sale let me know. (pantera, superboat, ect)
