Super Vee Fury
yeah i thought the ilmor's had more horses?????
it's the ASD's Rik
Thats the problem.......boat has to be slower using those things ,they suck about twice the hp of a #6 drive![Bsflag](/forums/images/smilies/more/bsflag.gif)
some people will never learn
it's the ASD's Rik
A to Z
Sean,
It is running fast then 105, but like i said still have a lot of work to do.
We have more HP in our boat and seeing some really good numbers, the boat handles and run alot better with HP. We r getting close I think we have the drive heights finally right now, and we just need a few gear changes, and some prop testing and we should be there. It took a while to get the balance and drive height to work with the extra weight the new motors added and all the extra fuel we have to carry now. It has been an intersting project and finally paying off. We are really looking foward to see what happens in clearwater . Still have a few bug but we know it would take time, we had a great run in NY till we broke in the 14 lap. The only plus out of that was we broke in 1st place, but u have to finish to WIN.
arneson-industries.com
Arneson Surface Drives www.arneson-industries.com
They ran 108 the first day in the water with temperature problems, loose hoses on the coolers and such and 400 lb of lead in the bow. Moving things around, addressing the cooling (those blue impellers are not good) and getting some propellers will improve the speed even more.
I don't think it will be the fastest boat out there, (wasn't with the 525's and Bravo's) but it should be when running in P1 Evo class and it can be very competitive running in the teens and most imporntantly reliable, which means a lot when you have to race back to back races in a single weekend hoping from country to country.
A to Z
Don't worry, it is faster than Sean predicts. They are going to run it again tomorrow with some different propellers hopefully.
I hope it goes 120 for the new owner, Will and everybody else involved, it's just not there yet.
Sean, from your quote it infers they should have probably stuck with the 525's and Bravos when it has went faster now than before and you know as well as everyone else, the boat was never a 105 boat and by Wil's admission none of them ever went that fast. So first time in the water, on the bump box, over heating, pumping all the tranny fluid and p.s. fluid into the bilge and still running 108 with nearly 2K more weight is a jump up and a significant one at that when this is a race setup which makes it to date more than a 10 mph bump in speed with more to come. Wil says it weighs close to 10K at this point and to make weight in P1 it will have to weigh 10,780 lbs on pull out.
If I wanted a kilo setup it would be different than it is now, but the boat should run (hopefully) in the mid teens tomorrow. If they can get the right propellers (everyone's story) maybe even more but 120.. Never.
And it does not have to in the P1 Class Evo as an honest 110 race speed will be competitive especially when they will have to race with the new torque meters I saw in Sweden. Things will change there.![EEK!](/forums/images/smilies/eek.gif)
Anyone have an 18X36 6 blade Hering??
![Smilie](/forums/images/smilies/smile.gif)
![Thumbs up](/forums/images/icons/icon14.gif)
