39 Rockit Specs.
39' Rockit
110+ mph w/ Twin Mercury 700's
Length: 39' 10"
Beam: 8' 7"
Fuel: 240 Gallons
Approximate Dry Weight: 9500 lbs
Cabin Height: 5' 4"
Standard Power – Twin Staggered Mercury 700's w/NXT1 Drives
Standard Equipment:
Dash, wrap around w/ complete Gaffrig
instrumentation: magnetic compass,
oil pressure, water pressure, fuel press,
oil temp., water temp., tachometers,
and all circuit breaker protected
Monster gauge upgrade
Single key ignition system
Depth finder
Dash mounted stereo remote
Dave Clark intercom (2 place)
SmartCraft w/ Mercury Racing Engines,
includes: trim & tab indicators, boost,
fuel pressure, fuel temp, water pressure, fuel level, volts & water temp.
Cigarette lighter/12 volt receptacle
Cockpit grab rails
Integrated custom dual driver/passenger
wrap around race bolsters w/ electric
seat cushions
Coaming pads
Three person rear sit down bolster seat
Fire Extinguisher
Stepped cabin door for deck access
Hardin Stainless throttle/shift system
Electric battery switches w/ key, remote
mounted race type
Jumper posts
Cockpit cover, felt lined w/ zipper
Cockpit lights
Cockpit storage w/ side doors
Safety ignition cut-off switches
Cockpit floor, non skid fiberglass
Snap in cockpit carpet
Custom steering wheel
Remote hatch lift
Waterproof tab switches
Dock Mat
Dock Lines (1 set)
Mustang Life vests (2)
Automatic fire extinguishing system
Bilge pump, electric automatic (2)
Electrical bonding system
Race mounted trim pumps for Kiekhaefer
trim tabs/drives
Kiekhaefer trim tabs
Oil changer
Diamond plate on engine room floor
Bilge blower
Engine room lights
Fume detector
Custom hydraulic twin cylinder power
engine hatch w/ 2 sunpads
Thru Hull Exhaust
Show engine room rigging & finish
Optimum battery's, heavy duty w/ race
type mounts
External tie bar
Performance race mounted installation,
race rigged
U.S.C.G. Approved fuel lines with
shutoff valves in cockpit
Single inlet fresh water engine flush.
Aerodynamically styled deck
Stainless Pull-up cleats, bow, mid, spring,
& stern
Anchor locker
Fender cleats (2)
Navigation lights
Windscreen
Swim platform, fiberglass
Horn
White/Black Rubrail w/ SS insert.
Rev. 2/4/08
Vinyl interior on walls & ceiling
Two couches, face to face
S/S latches all doors
Cabin carpet, snap-in (same as cockpit)
Removable ice cooler
Storage compartments, V-berth & bunks
Valances, vinyl covered
Enclosed head w/ port-a-potti & clothes
hanging bar
Interior lights
Stereo w/ AM/FM CD & 4 JL speakers,
1 sub, 4 tweeter, & 900 amp
Carbon monoxide alarm
Vinyl upholstery
Custom mirror package in galley
Optional Power.
Mercury Racing 700 SCI w/ NXT1
Mercury Racing HP 850 SCI w/ SSM # 6
Mercury Racing HP 1075 SCI w/ SSM # 6
Mercury Racing HP 1200 SCI w/ SSM # 6
Ilmor 710 V10 w/ ASD #7
Other power packages available on request.
Length: 39' 10"
Beam: 8' 7"
Fuel: 240 Gallons
Cabin Height: 5' 4"
Standard Equipment:
Depth finder
Cockpit grab rails
seat cushions
Coaming pads
Fire Extinguisher
mounted race type
Jumper posts
Cockpit lights
Remote hatch lift
Dock Mat
Dock Lines (1 set)
trim tabs/drives
Oil changer
Bilge blower
Engine room lights
Fume detector
Thru Hull Exhaust
type mounts
External tie bar
race rigged
& stern
Anchor locker
Fender cleats (2)
Navigation lights
Windscreen
Horn
Rev. 2/4/08
hanging bar
Interior lights
Vinyl upholstery
Optional Power.
