What's the real weight of a 388 wet ??
Rob
I was wondering what the real world weight is? Hustler 388 Slingshot 500efi bravo,not a poker run edition,factory spec says 8500 dry,this is with full cabin interior,110v/battery charger,VHT,basic accessories etc.
Then like my 388 at run weight, with 750lbs of gas 30lbs of water,400lbs of ass,koolaid,extra stereo amps,sub box 85lbs,extra battery,2 Whipple and all the stuff with it 225?,B Max 50lbs ,tools 25lbs,anchors,arm floaties, lines misc junk 100ish. And a Mr Potato head
I'm guessing my weight is around 10200.lbs What do you all think? Has anybody actually measured one?
Rob
Rob
Rob
Boat with out motors,drives or fuel, dry weight,w/ myco alum trailer,2 spares,and 2 tool boxs full, 8820lbs boat and trailer
Im guessing the motors are 1100 each,drives 180 each,trailer maybe 3500,
03 4x4 dually was 7780lbs 3/4 fuel, f 4240 r 3540
lot of tounge weight with out motors etc,. truck trailer and empty boat 16600.
truck front 3760
truck rear 5420
trailer axels7420
it took weight off the front of truck with the high tongue weight
When I get it running Ill re weight and find out what the trailer weight and the boat is exactly
truck front 3760
truck rear 5420
trailer axels7420
Rob
Once I get mine back together I will reweigh and know for sure
Rob
Another boat,center console I bet?
Ive seen a few with out shorepower,Im sure it ads weight and $$,I remember when I was shopping new they wanted 15k for the cabin interior upgrade ,I put a inverter in to run a fan for the girls when they are doing there thing up front.
hey I thought you had already sold the Nordic? that makes what 3-4 boats ya got now like me Im not even running yet and its not really bothering me,
ill be going to the scale next week,should be ready to put fuel in and reweigh
Rob
Rob
almost there
Truck 3/4 full 7780-7740....,40 lbs diff,prob fuel
Truck,trailer,hull no motors gross 16600,
Truck w/ trailer and hull
front axle 3760
rear axle 5420
figured around 700 extra tongue with out motor,drive, fuel,
Boat and trailer,dry,no motor or drives, 8820.
Boat,trailer,motors and drives wet 12020.
The engines and drives with oil is 2779.
motors wet 2429. w/ 20 qts of oil
drives wet 375. w/ 2 gallons of oil
I added fuel that weighed 2 diff rates,scales go to tenths, 1st load was 6.11 a gall the 2nd load was 5.91 per pd gall, = 421lbs of fuel
after putting in 71.31 gallons of gas ,gauge showed 3/4 full on the boat?,I drained all I could last Sept,so I guess it had some left in it?
50lbs of stuff
no water
truck,trailer and boat wet,gross wet 19800.
front axle 3940
rear axle 4720
trailer 3 axles w/ boat 11140
I'm guessing total/gross when traveling is
Truck 84550,
Boat and trailer full fuel and water etc,12878,
21333, libras
Im guessing the trailer is around 3500?
Next ill get the trailer weight and then,Ill know the exact weight of the boat wet/running
Mississippi math
You can see the tongue weight was pretty high with no motors and drives, also the engine firewall/bulkhead is behind the trailer axles.
front axle 3760
rear axle 5420
50lbs of stuff
no water
front axle 3940
rear axle 4720
Truck 84550,
21333, libras
Mississippi math
Rob
I weighed the truck and trailer
Truck still 7780
Myco trailer 2480. thats alum,alum rims,2 spare tires,2 tool boxes full with spare parts,
truck and trailer 10260
Boat w/ 100-125 gallons gas 9540lbs, that would be a running weight with out people,ice,and 13gall water tank
So dry should be around 8790, thats with prob 50lbs of gear,and all the opt's the boat has
Truck still 7780
