Arnesons on 388's
#31
I rode in the Black Cloud 388 about 5 years ago during the 1000 islands poker run . That was one hell of a ride with those arnesons and twin 1000hp motors. The only complaint I heard about it was that because the best set up for the boat was to run the drives and props rotating inward that it at times was a handful to drive and had even hooked at high speed a few times. There a few times when I was in it where it felt a little squirley but it was an awsome boat! I have seen a new 344 Cheatah with arnesons for sale and it is the new sit down set up that thing looks like it should fly even with 525's.
#32
Do any of you guys know anyone running this setup? I am considering this for mine and would like to talk to a few people about it. Has anyone made the conversion?
Dean
Dean
#33
Rik which set up is this.
Rik On the Bravo conversion do you have to re glass the transom???
There looks like a lot of Hustlers are going to the Arnesons.
#34
arneson-industries.com
Those are ASD8-10" drop box drive units mounted on a 31 degree angle.
The boat has a set of Yanmar 440's in it and I think it runs 85-86.
Bravo conversion does not require you re-glass the transom as the standoff box covers the Bravo cutout. You have to open the transom up a bit for the transmission to fit through. Other than that, nothing special has to be done to the boat for a standard side by side application.
They work really well on the Hustlers, but the same can be said for all the applications so far.
#36
They use the SSM#6 propellers.
Typically, they use a 5 blade 16.5 diameter by what ever pitch is needed to run the speeds.
Midrange they pick up over 10 and top end 5 or more.
#37
Premiums, I notice you cant recieve pm's, could you call me collect when you get a chance, thanks Jeff 228-216-0900
#38
Originally Posted by Strip Poker 388
Nope ![Big Grin](/forums/images/smilies/biggrin.gif)
But he is doing a turbo motor . I cant see how it would work in a boat. I bet he gives up on it.
#39
correct me if i'm wrong .... but that's the old Gale Banks setup with throttle bodies and EFI?
it works ... but not too hi-tech in my opinion for what Keith is capable of.
#40
I am going to convert my boat to arnesons.
I'll let you guys know how it goes and post some pics later.
Anyone interested in a good set of xr's w/IMCO lowers?
Dean
Dean
