Antbody With A Single Thought Of Going To Arneson
I Was Wondering Your Guys Thoughts On A Mag With A Single Arneson 700 Hoarse.....
Some Of Ya Know I Have A Single #3 On There Now....
I Think The Drive Would Be More Efficient Further Back.......
JC Performance Engines
Re: Antbody With A Single Thought Of Going To Arneson
Single Arneson may be a bit tricky at lower speeds.
Konrad w/ an extension box may work.
I Am Just Trying To Get All The Nuts Out Of The Boat I Can.....i Know They Make A Ext Box For A #3 But I Cant Find One...
No Cig,was in sarasota on sat.and spent a little time with Travis,(Magnum 27) and had a chance to look over his Magnum.If i was going to change my Transome set up i sure would be looking at what he is using,that about as clean a set up you can get.As far as the konrad goes its a great drive but no better then what you have,and still uses a tranny.The ansewer to get your speed up is set back, X dimension, prop,and right drive without tranny. Just my opinion for what its worth. Mel
Hey Mel Always Good To Hear From Ya I Am Thinking Of Extension Box First To See What That Does, Still Not Spinning The Proper Rpm About 5700, Want To Be Around 6200......i Will Keep Ya Posted......runnin Good
The arneson would be a good alternative to the #3. You would need a drop box unit to get it where you want it and get the gear ration you would need. Not sure if a #6 would be big enough. Try Rik here on the board he would be the best to talk to.
No Cig,how you coming with your Mag.You posted you were turning 5700 rpm,what kind of speed that give you?I would bet on 80 to82mph.but i dont know much about a chopper prop.I sold my 502 race eng.to a fellow to replace h is 330 with a trs drive, in his 24 Excaliber.The day after he got it in and took his first ride i think i could have charged him twice as much and he would have still been happy.That boat of his could be a 27 sport with three ft cut off.Its crazy how many boats out there are nothing but copys of the old 27 Magnums.Have a good day and be safe.
Mel
Mel
hey mel always good to hear from ya ...ABOUT 78MPH IS ALL I AM SEEING I WAS OUT ALL DAY YESTERDAY NEVER MUCH UNDER 4000 RPM....IT WAS A NICE CHOPPY DAY OUT IN LAKE ERIE I WAS BY MYSELF SO I TEND TO GET CARRIED AWAY.......I DONT LIKE TO PUSH IT WHEN I HAVE OTHERS WITH ME......RUNNING GOOD WOULD SURE LIKE TO SEE 80 I THINK I MIGHT SEND MY PROP OUT TO GET LABBED....
No Cig.when i was first putting Vixen together i really didnt know a lot about putting together a boat to get the most speed out of it,even thou i worked every day on new go fast boats.You can ask a dozen different peaple in the trade how to set somthing up and you cant get two to come up with the same answer.I finally went and sat down with Richy Sutphan in the Cape because he had been building an racing this type of boat for years,and was the best thing i ever did.You being in Mich. have one of the best up there and he knows how to get the most out of a Magnum.Give Tyler Crocket a call or go see him,i bet he can get you that 80 to 83 fairly easy.
Have a good one. Mel
