'75 magnum Maltese
I just bought a 1975 Maltese, boat is in process of complete Restoration. I mean complete. I will post pics as it happens. Motors are 350,s which are being built to 400+ h.p. Drives are Volvo duo props, and the X dimension has been raised. My question is upper 70,s to 80 m.p.h. realistic? Very excited about project, I have had a few different off shores, and always wanted a Magnum, cant wait till she's done. Any input on anything about them would be great!
cool project give us some pics does not matter what kind just like seeing the old mags.................upper 70's very possible but i dont know much about the drives........what kind of shape is the boat in..........post before and afters...............there is some real mag experts here get the pics to stir there intrest...........
www.msnusers.com/magnum
If you go to address above you can check out the pics. Restoration is just beginning, I will update as things change. The magnum will be white bottom, red hull sides, and white deck with red stripe. The windshield will be a custom fairing, not sure yet what style to go with. Should be done by April, I hope.
Mine was a 1970, full race conversion. Back in the day, the first set motors in the race boat were 355cid, 400+hp each. With Bravos and a low x-dim we saw 66 without nose cones, and 70 with them. Same engines, bravos with a high x-dim, we saw low 70s without nose cones(didn't need them). The final run, almost 10 years later, 374cid, 14:1 CR, headers, port work, mod carb, B-class stage II motor, 650+ hp each, 102mph. See thread below for info and pics.
http://www.offshoreonly.com/forums/s...8&postcount=31
specs and pics on mine www.dkorinc.homestead.com
As the GLSCS referee I had to DQ more than once Skips P5 Short Circuit Magnum with smallblocks & bravo's when they raced Grumpy's Mag, they both could run high 70's into the 80's My trs 350hp smallblock Mag [P88 Believe It] would run high 60's.
Sounds like a great project. Always wanted a Magnum....had a deal lined up on one, but wife killed it...wanted a cabin. Got an older 30 velocity....has cabin...wife still hasn't been in it. Boat has 350's and also Duo-props....interested to find out what you learn about the duo props and their ability to hold up.
Shafer 2222 you may have a 1974 Maltese based on the air/engine vents exiting the stern vs the top of the gunwale on either side of the engine hatch.Send me the ID# found on the stern just below the rub rail Starboard side and I will check it against the master list we have from Magnum. Bud
Hello Bud
Happy Holidays to you and your Family
Did you ever get the Master list for the 27 Sports?
Love to see a copy of that one.
Happy Holidays
Thank you
Jim
Happy Holidays
Thank you
Jim
