Go Back  Offshoreonly.com > Owners Forum > Magnum Marine
building a cradle >
building a cradle
building a cradle
Old 07-10-2014, 02:11 PM
I decided to go with 8" steel casters I like that they will never ever flat spot, and the 8" diameter will help them roll with weight on them. I am going to mount them off the top of the stand to keep the boat low I plan on keeping the keel about 13-15" off the ground.
http://www.northerntool.com/shop/too...ct_40256_40256
murfman is offline
Old 07-10-2014, 11:32 PM
scippy's Avatar
Originally Posted by murfman
Where did you get the casters and the swivel brackets? The only casters theat HD that I've found are over 200$ a piece
Murf.........I sent you a PM..................the casters came from a factory close-out sale (something like $15 apiece) as far as the hull pad swivel brackets??...........
picture a playground "see saw"
scippy is offline
Old 07-10-2014, 11:37 PM
scippy's Avatar
Originally Posted by Fast Shafts
Harbor Freight has a great selection of casters.
I saw Pete's (Scippy) in person and I'd give it a "10"!!
By the was Pete, how is the Magnum coming? I'd love to stop by and check it out!
Bob
Hey Bob............make some free time and c'mon by!........as far as the mag - everything I'm doing is slow, but i'm getting it right!
scippy is offline
Old 07-11-2014, 11:47 PM
h2oboater's Avatar
Those wheels will work just fine. The cradles & casters that Klem used in making the Magnum knock offs were never that good and he never dropped a hull when I was around
h2oboater is offline
Old 07-12-2014, 10:44 AM
mr vinyl's Avatar
Pete ,your dolly looks slick...you should publish a sketch on our site for someone else may want to make a pair.
Also need you to send the life line to my supplier...Jeff Schuster, Rigging Only...,50 4th St....Fair Haven Mass.02719 and tell him the length you needed in cut down to. He has some of my parts so he can get it done.
mr vinyl is offline
Old 07-12-2014, 11:22 PM
scippy's Avatar
Bud .........I'll give you a call before I send the lifeline off to Jeff !...........Thanks
Murfman........I measured the dolly and it is 25" X 48" I used doubled up 2 X 6's for the outside perimeter.........hope this helps!
scippy is offline
Old 07-13-2014, 09:53 AM
Thanks. I'm going to make the base out of C channel. I'll start cutting it today. The wheels are supposed to be here Tuesday.
murfman is offline
Old 07-13-2014, 10:44 AM
And Bud, thanks for the insight the other day, you helped me make my decision easier. I'm leaving on the 31st to go pick it up.
murfman is offline
Old 07-13-2014, 03:22 PM
mr vinyl's Avatar
I don't think you can go wrong...let me know what it looks like when you have it in IL. Might come down and see it ,your not that far. Bud
mr vinyl is offline
Old 07-13-2014, 03:59 PM
I believe you meant "fort" st.
Unlimited jd is offline
