Setups on 30 Outboards
Anybody have any tips ?
I have a 30 with 2.5 efi's everytime I work on it we go slower.
Best speed since engine rebuilds 92.
I need to raise the motors, but I cant get one to turn up, its been in the fiberglass shop for 3 months. Im having the back seat permantly attached, and getting nicks and dings fixed.
When it gets back it will also have a new interior.
Curtis
Curtis
Yahoo, I have a 2000, 30 ft w/ 2.5 efi ro's . I bought it with one bad powerhead. I fixed the powerhead and I had it out for one run , but I could not run it hard due to breaking in the new P.H. I since have ran out of good weather here in the northeast. If the weather breaks at all soon I will run the boat and give you my results . Tom
I have a 30 with twin 300 promax 's best speed so far has been 110mph
motor height is 1 7/8'' above the bottom on 5'' set back cmc plates. 15''x34'' cleavers turning OUT . I tried turning the props turning IN and lost 4-5 mph in back to back runs. I also tries 14 3/4'' diameter props and slowed way down My boat weighs 4400#
thanks thats info I can use, all my props are like 14.5 or smaller. First thing Im going todo is turn them out and check the drive height.
Now I just need a little bit better weather.
CM
CM
The 300X uses a 1.62 gear ratio as it does not turn RPM. It is a torque motor. The 2.5's like the 1.87 best. They like RPM. You must run 15" props on your boat. 15x32 will probably be the best setup.
