Canton Racing Oil Pans
Canton Racing BBC Billet Remote Oil Filter Adapter - Gen 5&6 - Click for pricing
Big Block Chevy Billet Remote Oil Filter Adapters are designed for wet sump systems where a remote filter is desired. They mount on the block, replacing the stock bypass and bolting into the mounting holes left after the bypass is removed. Complete with hardware and O-ring seals.
Melling BBC High Volume Oil Pump (M-77HV) - Click for pricing
25% higher volume over stock.
The gears are machined out of steel billet and the drive gear is pinned to the shaft.
Screen inlet is ?” and will accept original equip screens
The housing and cover are CNC machined and manganese phosphate coated for wear and rust prevention.
If there is something I can help with hear, let me know & I will try to answer your questions.
Thanks,
Don B.
